Author: Subject: Front wishbone mount reinforcement
Slimy38
posted on 9/6/14 at 01:52 PM Reply With Quote
Now I've got the jig in place for the front wishbone mounts, I can see why people are concerned about the front mount. With the rear mount central to the upright, the front mount really hangs off a lot, even though it looks spot on in comparison with the picture.
Has anyone added any reinforcement behind the overhanging section? Or is it reasonably ok?
Smoking Frog
posted on 9/6/14 at 03:04 PM Reply With Quote
My Indy has some, so I'd say it does need beefing up.
ste
posted on 10/6/14 at 04:59 AM Reply With Quote
Here's a pic of mine, you can see the reinforcements on the front upper mounts
Slimy38
posted on 10/6/14 at 07:48 AM Reply With Quote
That's excellent, thanks. That's pretty much what I was going to aim for, just a small plate to support the free end.
Thank you both for the replies.
Fred W B
posted on 10/6/14 at 06:44 PM Reply With Quote
I'd close off the top and bottom as well, if you only fit the vertical gusset plate you won't be able to prepare/paint properly behind the plate and will have red rust running out for ever after.
Regards
Fred W B
Slimy38
posted on 10/6/14 at 08:17 PM Reply With Quote
Yup, I was planning on cutting a profile out of square tube that would sit behind and form an enclosed box.
Ste, I forgot to ask, am I right in thinking that's round tube on the diagonals? What's the thinking behind that?
posted on 10/6/14 at 09:20 PM Reply With Quote
When I built mine I put an extra bit of section between the FU and the front of the chassis to support the brackets. You'd need to make sure the coil over clears it though.
ste
posted on 10/6/14 at 10:29 PM Reply With Quote
yes, i did a lot of my front diagonals in 19mm chs. it is stronger in compression than rhs and also cheaper and lighter.
