bigwill64
| posted on 12/6/14 at 08:06 PM |
pedal box
does anyone have drawings or blue prints for making a pedal box thanks in advance.
designer
| posted on 13/6/14 at 09:37 AM |
They are in the Haynes book.
Rod Ends
| posted on 13/6/14 at 01:26 PM |
Have a look on the Tilton, Wilwood & AP Racing websites for dimensioned drawings of their pedal boxes.
bigwill64
| posted on 20/6/14 at 08:36 PM |
pedal box
was hoping for some ones bright ideas for pedal box not something standardish.
K13JOB
| posted on 20/6/14 at 08:56 PM |
Pedal box design has been tried and tested over many years, what kind of bright ideas were you expecting?
Perhaps you could build it using unobtainium and make it spherical with a one pedal combined reservoir remote control system
mark chandler
| posted on 20/6/14 at 09:24 PM |
I just cut some brackets so I could hang pedals off the bulkhead top rail and made some pedals, brake out of 1" box, clutch 1" tube and
used a throttle pedal I had lying around.
Not a great picture but you can see the work in progress.
  Steering and pedals 12 Feb 06
Clutch is cable so pulls above the pivot, brake has a rod so made a strong bulkhead and bolted the master cylinder to it.
The pivots are bolts, I welded tube into the box to match, they are made from off cuts so free, to finish some 1/4" plate then bolted on cheap
halfords aluminium pedal covers.
Linky<
br />
Regards Mark
[Edited on 20/6/14 by mark chandler]
bigwill64
| posted on 21/6/14 at 01:28 PM |
Pedal box
bigwill64
| posted on 21/6/14 at 03:12 PM |
Pedal box
Why doe there always have to be a sarcastic comment posted when anyone asks a sensible question?
43655
| posted on 22/6/14 at 04:02 PM |
Not quite sure what you're after that's not a standard item?
but wilwood ave some very nice drawings with their products, does this help at all?
http://www.wilwood.com/Pedals/PedalList.aspx
