Author: Subject: Steering Column Shaft
Furyous
posted on 1/7/14 at 09:48 AM Reply With Quote
I bought THIS steering column to replace a welded lower column (Can't have a welded steering column in NZ). Unfortunately, it's 30mm too short. I'm sure there were a choice of lengths when I bought it, but now I can't seem to find any others.
Does anyone know where else I can get a slightly longer one? This one is 330mm. Something close to 400mm would be good, because then I could move the wheel a little closer to the seat. As it is, I would need a shaft 360mm long.
Myke 2463
posted on 1/7/14 at 10:11 AM Reply With Quote
Try this http://www.rallydesign.co.uk/product_info.php?products_id=11805
Be Lucky Mike.
mcerd1
posted on 1/7/14 at 10:39 AM Reply With Quote
I think they are both the same length...
how about mount the steering wheel 30mm closer to the dash and using a boss adapter / spacer thingy to move wheel back towards you ? (does that make sense?)
gremlin1234
posted on 1/7/14 at 01:37 PM Reply With Quote
the page you link to, THIS
also has different lengths of uj/couplings for the lower joint. (short and long)
edit
http://www.motorsport-tools.com/escort-mk1-mk2-heavy-duty-group-4-short-steering-coupling-universal-joint-forged.html
and
http://www.motorsport-tools.com/escort-mk1-mk2-heavy-duty-group-4-long-steering-coupling-universal-joint-forged.html
[Edited on 1/7/14 by gremlin1234]
Furyous
posted on 2/7/14 at 06:19 PM Reply With Quote
The trouble with that is it would move the column mounted stalks into the dash.
edit
and
Those would give an extra 40mm, which would work, but at £50 each I think I'd like to try another option if I can!
Kdempsie
posted on 2/7/14 at 07:08 PM Reply With Quote
Carbuilder solutions do one that is 400mm with both ends 9/16" splined.
Have a look here.
[url] http://www.carbuildersolutions.com/uk/double-ended-splined-shaft [url]
[Edited on 2/7/14 by Kdempsie]
Furyous
posted on 3/7/14 at 03:59 AM Reply With Quote
Have a look here.
Aha! I completely forgot about CBS. I'm pretty sure that's where I saw the different lengths before. I'll give that one a go. Thanks!
