Author: Subject: escort quick rack lock stops.
Jenko
posted on 14/7/14 at 04:15 PM Reply With Quote
Done a search, but couldn't conclude on the correct answer.....How do you add them?, and what do you use? :-)
MY BLOG - http://westfieldv8.blogspot.co.uk/
prawnabie
posted on 14/7/14 at 04:29 PM Reply With Quote
You can use split collars, but beware of the size as on one side of the rack the lock stop needs to go inside the rack on full lock and will really limit travel if it is too big,
Andy S
posted on 14/7/14 at 04:31 PM Reply With Quote
Jubilee clips do the job and different widths will give you different restrictions - on the rack just behind the knuckle.
mark chandler
posted on 14/7/14 at 05:00 PM Reply With Quote
I used an inch of thick walled tube that fitted neatly on the rack, split it then used a jubilee clip to old it together.
Jenko
posted on 15/7/14 at 06:39 AM Reply With Quote
OK...cheers chaps, will get on to this.
