ceebmoj
| posted on 14/7/14 at 09:00 PM |
What brake master cylinder size with Wilwood calipers
So as the title asks what brake master cylinder have you used with Wilwood break calipers? I have had a look at the following articles.
Car Builder Solutions, hints and tips
super 7 th heaven
Unfortunately I don't have the pedal to hand to measure so cant go with the 7th heaven approach at the moment. The break pedal has a balance bar
installed and I have the following Wilwood calipers.
Frount 1.38" 35.1mm
Rear 1.00" 25.0mm
[Edited on 14/7/14 by ceebmoj]
adithorp
| posted on 14/7/14 at 09:38 PM |
I've got 0.625" front and 0.7" rear master cylinders with front and rear Wilwood Powerlites.
http://jpsc.org.uk/forum/
ceebmoj
| posted on 14/7/14 at 10:22 PM |
I'm also using Wilwood Powerlites, do you know the piston size on your calipers?
adithorp
| posted on 14/7/14 at 10:42 PM |
I believe the Powerlite pistons are 31.8mm dia
