Author: Subject: Measuring up for rack extensions
edthedrummer
posted on 19/7/14 at 11:31 AM Reply With Quote
Probably quite a simple question to answer,
Its obvious to me that i need rack extensions, i have quite an amout of toe in at the minute.
If i measure across the front axle, from the inside of each brake disc across the front, and the inside of each disc across the rear of it, the difference in measurements is 55mm.
Do the rack extensions come in near enough sizes, and then the fine adjustments can be taken up with the track rod end?
Any places reccomended to buy them from or to avoid altogether?
Ed.
Ben_Copeland
posted on 19/7/14 at 04:58 PM Reply With Quote
http://www.rallydesign.co.uk/product_info.php?cPath=900_1670&products_id=14661&osCsid=5k4mmqfprpvv71u1sl3864c536
http://www.rallydesign.co.uk/product_info.php?products_id=21723
Any good ?
Ben
Locost Map on Google Maps
Enter Your Details Here
kingster996
posted on 19/7/14 at 07:16 PM Reply With Quote
I have some from an mk indy sierra rack.
If they are what you need then you can have them for postage costs.
Chris
I used to be indecisive, but now I'm not so sure
kingster996
posted on 20/7/14 at 07:12 AM Reply With Quote
And there's a pair here if mine are no good
