superchared
| posted on 21/7/14 at 09:15 AM |
Multi Link IRS
Hello,
I am using BMW E60 M5 rear hubs for another car I am building and was wondering if anyone used 4 individual control links for the rear suspension
rather than a lower wishbone and two upper control links.
I am thinking of using this setup so I can achieve maximum adjustability in the suspension as it will need to be changed regularly. Push rods are
used for the actual connection to the coilover and these come from the original mounting hole in the hub so they do not interfere with the control
link.
What is everybody elses opinion on this, would strength be an issue?
Slimy38
| posted on 21/7/14 at 10:48 AM |
I'm not sure whether this answers your question or raises new ones, but how will it work with regards to power transmission? My limited
suspension knowledge only extends to multi link IRS where there is a solid axle involved.
| posted on 21/7/14 at 11:44 AM |
quote: Originally posted by superchared
Hello,
Have you got a picture/drawing of your idea? I don't quite see how you would rigidly locate a rear upright with four separate links and no
wishbones.
43655
| posted on 21/7/14 at 08:25 PM |
isn't it just 2 separate arms instead of a regular top wishbone?
Overcomplication IMO
