Author: Subject: front end knocking
luke2152
posted on 21/7/14 at 08:44 PM Reply With Quote
front end knocking
Well I've finally gotten to the stage where I it will move under its own steam and had to take it for a little blat outside the garage. Definitely put a smile on my face.
I have a knocking in the front end as the suspension starts to rebound and I can't for the life of me find the cause. Everything torqued up and checked. I can replicate it bouncing the front end by hand but still can't find it. There is a very little play in the steering rack (refurbished mk2 escort) but I don't think that is where it is coming from. Any hints?
ReMan
posted on 21/7/14 at 08:59 PM Reply With Quote
Definatly knoking and not just heavy creaking from the wishbone bushes??
right size bolts/bushes used on suspension eyes/bushes?
one side or both?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
luke2152
posted on 21/7/14 at 09:10 PM Reply With Quote
definite knocking I can feel it clunk/click with my hands when I bounce it. And it appears to be both sides but they do move together so it is hard to tell.
ReMan
posted on 21/7/14 at 09:46 PM Reply With Quote
need to get someone else to bounce it while you feel around it, see if you can zone in a bit closer to the source
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
luke2152
posted on 21/7/14 at 09:54 PM Reply With Quote
Yep thats the plan will try to find a friend tomorrow!
fesycresy
posted on 22/7/14 at 04:59 AM Reply With Quote
1/2" holes M12 bolts ?
Ben_Copeland
posted on 22/7/14 at 06:12 AM Reply With Quote
What are your shocks like? I had a leak in a new protech shock that banged on the road but not on driveway
Ben
Locost Map on Google Maps
Enter Your Details Here
luke2152
posted on 22/7/14 at 06:26 AM Reply With Quote
M10 bolts and crush tubes all supplied by gbs
luke2152
posted on 22/7/14 at 06:29 AM Reply With Quote
Used nitrons tested by procomp and new springs fitted. However they came with springs loose so I may have wound the spring up too loose or too tight
[Edited on 22/7/14 by luke2152]
