| posted on 30/7/14 at 12:21 PM |
mintex 1144 pads -do i fit them?
Trying to improve my braking distance so have fitted drilled-grooved disv and got s set of mintex 1144 pads.
On the box it says: this material must not be used on public highways.
So should i fit them or not?
Also in the box are four self adhesive pads. I am guessing they go on the back at the front, similar to the steel shims.
Do I used them without the shims or with the shims? Or not at all?
I dont race round like crazy but more or less pootle along - my understanding is that certain compounds work better when hot , something not likely
with my style of driving.
I looking for good grip with cold discs and pads.
[Edited on 30/7/14 by 02GF74]
monkeyarms
| posted on 30/7/14 at 12:29 PM |
I have them on my J15, at 500kg and 125hp the brakes work great from cold, hot and trackdays
I put the sticy pads on and use shims, no problems.
Good pad for kit cars I think.
[Edited on 30/7/14 by monkeyarms]
adithorp
| posted on 30/7/14 at 12:34 PM |
Fit them; You'll notice a big improvement. I would fit the shims as well as they are known for squeeling (though I've never suffered).
There was a thread last week with the correct bedding in procedure.
Drilled/grooved discs won't improve stopping distance under normal circumstances. They'll just reduce glazing (while increasing wear rate)
and reduce fade under extream use, when the pads start to gas.
http://jpsc.org.uk/forum/
| posted on 30/7/14 at 01:04 PM |
Where did you stick the pads?
I am guessing the front hallf at the back and make small hole for the pin?
Off to google as i am sbout to fit them.
monkeyarms
| posted on 30/7/14 at 06:20 PM |
I cant remember specificaly, but i dont think i had to make a hole, just stuck them on I think.
I have Ford M16 calipers if that makes any difference?.
snapper
| posted on 30/7/14 at 06:22 PM |
1144's are fast road
1155 are track
Check your numbers
Or
Perhaps
They were imported from a country that does not allow these modifications
I eat to survive
I drink to forget
Surrey Dave
| posted on 30/7/14 at 07:46 PM |
They Are Fab!
Mintex 1144 best thing I ever did for my Locost/Cortina brakes...............
Don't hesitate.
mcerd1
| posted on 31/7/14 at 01:56 PM |
they have to say 'must not be used on public highways' as they don't have the relevant approvals for some reason or other
Reg 90 says the friction must be within 15% of the original's for that application - so maybe M1144's are too good ???
approved pads should have an 'E11' mark on them
so technically if you had an accident and the found that the pads weren't approved you could be held liable (just like if you bought tyres
without the right approvals for Europe etc....)
if you want to be 100% legal you could try the OE spec mintex ones (really good as far as OE spec goes and a lot cheaper too) but they won't
perform as well as the M1144's
[Edited on 31/7/2014 by mcerd1]
eddie99
| posted on 31/7/14 at 02:24 PM |
1155 are track
Check your numbers
Or
Perhaps
1144 are soft, 1155 are harder than 44, and 66 is harder again
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
Surrey Dave
| posted on 31/7/14 at 02:25 PM |
I Like It!
Mintex 1144 pads may not conform to European Standards but you will be able to stop BUT you could get sued or not paid out by insurer if you have an
accident
OE pads will conform but will only make a mild rubbing noise , with little retardation so you are more likely to have an accident ,but at least you
won't get sued!!! ..........I'm getting OLD!
[Edited on 31/7/14 by Surrey Dave]
| posted on 31/7/14 at 03:10 PM |
How could anyone tell what brake pads you have fitted anyway , even with a strip down!
The only major case involving upgraded brakes I know of was a serious one involving an idiot who fitted a Range Rover front calliper to one side only
on LR Defender.This would give almost 50percent more braking on one front wheel.
The consequences were tragic but nobody on this forum is that big an idiot.
[Edited on 31/7/14 by britishtrident]
loggyboy
| posted on 31/7/14 at 04:25 PM |
Depends on the severity of the accident, if deaths/serious harm are involved, police will full inspect the vehicles involved. I would suspect the
smallest markings left on the back of the pad (names/part no's etc) would identify them.
Mistral Motorsport
