Fred W B
posted on 7/8/14 at 05:35 PM |
Cortina upright to spherical bearing adaptors
Evening all
I'm looking to either source or have made some Cortina upright to spherical bearing adaptors . Before I spend a lot of time on google or drawing
maybe someone has a link to a supplier or drawings of said parts they would be willing to share?
Regards
Fred W B
[Edited on 7/8/14 by Fred W B]
posted on 7/8/14 at 07:02 PM |
McGill Motorsport sell the bearings and cups.
The Midlana is designed to replace the top ball joint with a spherical.
Doctor Derek Doctors
posted on 7/8/14 at 07:56 PM |
I have a full set of tapered pins to convert Cortina upright to use 5/8 spherical bearings top and bottom. Made by David Dickerson (can't
remember his user name) from this site, from Stainless steel. Also have a set of strengthened Rally Design wing stays that clear them.
Edit just spotted you are SA which is a bit far away. I will look to see if I still have the drawing I did to have them made from.
[Edited on 7/8/14 by Doctor Derek Doctors]
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
Fred W B
posted on 8/8/14 at 04:22 PM |
Thanks for the responses
That would be appreciated Derek
Fred W B
