gallons perminute
| posted on 25/8/14 at 09:06 AM |
steering rack for a car with a central seat.
I am looking for a steering rack for a car with a central seat. Most racks have the pinion at an angle to the rack. Does anyone know of a steering
rack where the pinion and rack are at 90 degrees? I only need the rack and pinion so the casing shape does not matter.
Thanks.
CNHSS1
| posted on 25/8/14 at 09:39 AM |
Dermot Healey will have an ex-single seater jobbie for you, no problem.
this 750MC racer uses a Fiat Punto rack iirc, scroll down the pdf and theres a cracking shot of the rack and front suspension
http://www.racekits.co.uk/Practical%20racer-%20750F%20Falcon.pdf
ettore bugatti
| posted on 25/8/14 at 11:37 AM |
Article mentions Cinquecento and Seicento donors.
designer
| posted on 25/8/14 at 11:53 AM |
There's also Porsche 911
iank
| posted on 25/8/14 at 05:54 PM |
Russboss also uses the Cinq rack on the Furore
Pic here -> http://www.locostbuilders.co.uk/viewthread.php?tid=182983
Anonymous
Sam_68
| posted on 25/8/14 at 06:53 PM |
You're going to need exactly the right rack length to work with the rest of your suspension geometry, otherwise you'll get some degree of
bump steer, so why not just call Titan or Jack Knight and tell them what you want, complete with choice of ratio?
In the grand scheme of things, the cost isn't that great, particularly if you only want the rack bar and pinion, not the housing.
The alternative (unless you faff about shortening/extending the rack bar) is that you have to let the tail wag the dog, with the rack length and
steering arm geometry of your uprights dictating the rest of your suspension geometry, which doesn't seem sensible?
gallons perminute
| posted on 28/8/14 at 10:14 AM |
Thanks guys,
nothing suitable it appears as the Fiat rack is at a very slight angle.
Looks like I will have to spend big.
sickbag
| posted on 28/8/14 at 10:23 AM |
Apologies if I'm mis-reading your requirements but does anything here help?
http://teamterrificracing.net/TitanNorthAmerica/SteeringRacks.html
There's a link to their parts list on PDF at the bottom.
Finally back on the job!
gallons perminute
| posted on 30/8/14 at 11:44 AM |
I have used Titan racks before for some of my projects but this latest one needs to be in keeping with the Locost ethos.
Thanks for posting.
