Author: Subject: Cycle wing brackets
Ixwa
posted on 5/9/14 at 10:57 PM Reply With Quote
Cycle wing brackets
My car has Cortina uprights which are worn and I decided to replace them with Rally Design alloy uprights but I have discovered a problem, how to fit the cycle wing brackets as there are no locating bolt holes. Has anyone found a solution to this problem. Your help would be appreciated.
jossey
posted on 6/9/14 at 02:23 PM Reply With Quote
from what I heard the rally design uprights are brittle?
might be wrong though...
Ive seen people mount them to the allen key bolt where the trackrod arm attaches if they are the same as they used to be...
does it have the bolt on arm?
David Johnson
Ixwa
posted on 6/9/14 at 11:49 PM Reply With Quote
Cycle wing brackets
Thank you for your comments. I sincerely hope the hubs aren't brittle! The hub has the bolt on track arm. I presume any fitment will be under the track arm thus altering the track rod dimensions.
jossey
posted on 7/9/14 at 09:30 PM Reply With Quote
Correct with adjusting the track rod.
I maybe wrong with the comment about being brittle a few people have mentioned it in the past at race meets etc as I had been looking for ways to reduce weight
David Johnson
