phil clegg
| posted on 18/9/14 at 06:58 AM |
wishbones
I have rose joints on mine,been on four years works fine,i put the cheap McGill e bay joints on with the rubber boots , 1 joint failure only where I
damaged a boot,so boots are a must,plenty of adjustment.
whitestu
| posted on 18/9/14 at 07:15 AM |
I've got those joints on mine without boots. When you say the joint failed, what actually broke?
Stu
phil clegg
| posted on 18/9/14 at 06:24 PM |
wishbones
this was supposed to be a reply to the use of rosejointed rear suspension on a Haynes.i have front and rear rosejoints,no actual fails just some wear
detected in the one with a split boot,this seems to me like the boots really work.
Lew The Machine
| posted on 19/9/14 at 01:26 PM |
Just spotted that... was that for me?
mc gill it is!
ITS FINE! i welded it!
scutter
| posted on 19/9/14 at 04:59 PM |
Phil, you still need to put some photos of your car in your photo archive. I'm sure some near you could help. It'll help me through my
home improvements and ensure I get back the build.
As for Rose joints I agree, without protection mine showed signs of wear in about 12 months.
ATB Dan.
phil clegg
| posted on 19/9/14 at 10:07 PM |
photos
as a shed man I have few friends,my wife might put some pics on,i have just removed my twin side pipes[r 1 cans] and replaced with a singal
exit,sounds and runs better,depends how far you are with your exaust....
scutter
| posted on 20/9/14 at 03:00 PM |
  Side pipes
I'm here with the exhausts, only £200 for parts for both sides, just need the primaries really.
ATB Dan.
phil clegg
| posted on 22/9/14 at 06:50 PM |
to scutter
search u tube, Ormskirk motorfest,jeffrey Patrick webb,,also Bernie dando and highlights of my first time,,you should find pictures of mine its black
and red,,,
