joneh
| posted on 28/9/14 at 12:23 PM |
Steering Column OK for IVA
Could someone tell me if this column is ok for the IVA? Not sure if its a collapsible type?
Many Thanks,
Jon
CosKev3
| posted on 28/9/14 at 12:47 PM |
Pretty sure that is collapsible, as the smaller diameter part will push up into the bigger upper part?
But can't remember what iva states is needed off hand
snapper
| posted on 28/9/14 at 01:44 PM |
Column needs to deform away from the occupant so offsetting the column with the UJ's covers most of the recomendations
I eat to survive
I drink to forget
joneh
| posted on 28/9/14 at 02:16 PM |
Excellent, I'll add this to the refurb pile then!
Thanks.
corrado vr6
| posted on 28/9/14 at 07:33 PM |
Don't you need two collapsible items?
On my IVA I tried saying that my Sierra column was collapsible due to the pin would break and the outer would slide down the inner, however my tester
wanted two items hence I had to fit a collapsible boss
http://r1indy7.wordpress.com/
CosKev3
| posted on 28/9/14 at 08:03 PM |
Think he's wrong there, as a sierra column has two collapsible points, the lower triangle shaft part will push up into the upper part, and
you've got the corrugated part at the top too
corrado vr6
| posted on 28/9/14 at 08:07 PM |
Ah now you mention it I was missing the corrugated section due to having an MNR column so now I remember why I had to have the collapsible boss
So Ignore me lol
