donn006
| posted on 15/10/14 at 07:07 PM |
Live axle disc conversion
Hi all this subject has prolbably been discussed before but I'm in the middle of doing a rear disc conversion to my rear axle I've got
all the parts (I think) I've got mk4 golf rear calipers escort mk4 front discs and the weld on brackets ,, I've got the half shafts ground
down so the discs fit over ,the problem I'm having is the caliper carrier will only fit at the top as if I try and mount it to the rear or front
it fouls the axle / half shaft secering bolts the discs are 239,5x10,2x8,7 if that makes sence to anyone
ali f27
| posted on 15/10/14 at 08:49 PM |
Hi which live axel are you using sounds like you complcating
a simple job
donn006
| posted on 15/10/14 at 10:31 PM |
Cortina axle the one with the diff plate
tul214
| posted on 16/10/14 at 09:51 AM |
Chester sports cars used to do a kit for the Super 6 which uses a Cortina rear axle.
Pictures are here if it helps?
1.6 Raw Super6 sold
