JC
| posted on 27/10/14 at 04:16 PM |
Cortina Uprights HELP!!
Further to my post here I investigated more. As the passenger side calliper
fitted the drivers side (upside down), and transferring the hubs from side to side still left nothing fitting the passenger side hub, I turned my
attention to the upright.
By measuring, spirit level and by eye, I think the spindle is bent upwards - the hub sits out of true in this direction when you mount it and
that also makes sense with the (lack of) ability to fit a caliper.
HELP!!!!!
What can be done? - I guess Cortina uprights are rocking horse proverbial to replace and I want to avoid re making the entire front suspension to suit
a different component......
[img]
  Bent?
[/img]
mds167
| posted on 27/10/14 at 04:30 PM |
I'm sure someone of a more mechanical mindset will have a locost solution but if all else fails I believe Rally Design sell uprights of Cortina
geometry, £195 a pair.
"No, you can't lick the system; but you can give it a damn good fondling."
Doctor Derek Doctors
| posted on 27/10/14 at 05:10 PM |
That doesn't look very healthy, they are quite often used for stock car racing so perhaps its had a hard life. Cortina uprights pop up quite
often on here and ebay so i would just look for another pair.
Be quick:
locost kit car parts
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
Mark Allanson
| posted on 27/10/14 at 06:19 PM |
I have the drawings for this if you want to measure and check
JC
| posted on 27/10/14 at 07:52 PM |
Mark, that would be great, thanks!
| posted on 27/10/14 at 08:16 PM |
Ally replacements from raldes.
JC
| posted on 27/10/14 at 08:40 PM |
The Rally Design replacements are nice....but! It says the caliper brackets suit wilwood calipers - I want to stick with the M16s, and secondly, with
VAT and delivery they cost more than a 'Ron'!
43655
| posted on 27/10/14 at 08:48 PM |
i think the geometry is the same as the Wilwood Prospindles?
I have a pair here if you're interested / if it is actually damaged
JC
| posted on 28/10/14 at 08:03 PM |
Is it the pro spindles or the aluminium uprights you have?
On their eBay ad, Raldes say the Ali ones are not compatible with M16 calipers
43655
| posted on 28/10/14 at 08:57 PM |
the forged steel Wilwood ones
JC
posted on 29/10/14 at 05:03 PM |
Dimensions of the prospindles here
Not the same as cortina
I measured both uprights today. The good stub axle has a small amount of inclination - 0.3 degrees. The other axle is 1.1 degrees.
When the gap between the caliper mounts and the disk is measures, this results in a difference of 1/8th inch, hence the caliper not fitting.
Time for a 'wanted' posting
Ugg10
| posted on 6/11/14 at 11:41 PM |
Did you get this sorted, this guy has a set for sale http://www.locostbuilders.co.uk/viewthread.php?tid=193367
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
