Author: Subject: front uprights
loughlin1
posted on 27/10/14 at 05:48 PM Reply With Quote
front uprights
on the mk2 escort design for the roadster should the bottom and top uprights be straight facing up or the top a little off centre
loggyboy
posted on 27/10/14 at 06:54 PM Reply With Quote
I thought the roadster was sierra based?
are you talking camber or caster?
Would it prudent to add adjustment in to the design?
[Edited on 27-10-14 by loggyboy]
Mistral Motorsport
loughlin1
posted on 27/10/14 at 07:01 PM Reply With Quote
sorry i am using the BUILD A SPORTSCAR ON A BUDGET FOR £250 using cortina uprights
big_wasa
posted on 27/10/14 at 07:10 PM Reply With Quote
The top leans back its called castor. There is a cock up in "Ron's" book and the wishbones only give half the needed castor. If you make them to the book It will be much harder to get through Iva.
Very well documented as not only was the book wrong but other manufactures seemed to get it the same wrong
loughlin1
posted on 27/10/14 at 07:28 PM Reply With Quote
i have how do i fix that
ludsonline
posted on 13/11/14 at 07:32 AM Reply With Quote
It been covered on here before, but you need to move the top wishbone bracket back 11mm to give you the required castor
adithorp
posted on 13/11/14 at 11:32 AM Reply With Quote
Have a search for camber and self-centering. That should give you weeks of reading on the subject.
Making the brackets wider, so you can adjust the camber via shimming the wish-bone forward/back, would be my choice.
http://jpsc.org.uk/forum/
