Matt21
| posted on 11/11/14 at 02:31 PM |
Brakes
I'm just having a look into some bigger brakes for my MK indy
I have sierra 240mm brakes at the moment and team dynamics 15" alloys
Would a set of 280mm fiesta ST brakes be a straight fit? (i'll be buying discs and calipers)
Dick Axtell
| posted on 11/11/14 at 03:59 PM |
How much clearance between your existing calipers and your wheel ID? Is it enough to accommodate the "new" caliper position?
Matt21
| posted on 11/11/14 at 04:38 PM |
Here is a photo showing the standard/current brakes...
  A very wet day at croft!
as you can see, you can barely see them! so I dont think clearance is an issue, more the mounting I'm not sure about
are the caliper bolt holes the same as the sierra? do I need adaptors etc
CosKev3
| posted on 11/11/14 at 04:55 PM |
Should fit inside the wheel imo, but its the offset of the disc you need to check to allow the caliper to mount up correctly
