alfas
posted on 23/11/14 at 05:25 PM |
picture request: galvanised or yellow-passivated wishbones
i´m searching pictures of front wishbones from a sevenish car, which are yellow passivated or galvanized. i need those pics for getting an impression
about the looks.
any pictures or links to pictures are appreciated.
[Edited on 23/11/14 by alfas]
minitici
posted on 23/11/14 at 05:41 PM |
Zinc plated wishbones
![](/galpreviews/upperwishbones.jpg) ![zinc plated](/gallery/upperwishbones.jpg) zinc plated
![](/galpreviews/lowerwishbones.jpg) ![zinc plated lower](/gallery/lowerwishbones.jpg) zinc plated lower
[Edited on 23/11/14 by minitici]
alfas
posted on 23/11/14 at 05:57 PM |
wow that was quick.....
i forgot to mention i would refer a pic from front of the car with installed whisbones....
minitici
posted on 23/11/14 at 07:18 PM |
Sorry I don't have installed pictures of the zinc plated wishbones.
The zinc finish is not very durable if used in all weathers on a road car although you could probably clear coat them.
I have used nickel plating on wishbones and this looks a lot better.
![](/galpreviews/nickel.jpg) ![nickel wishbones](/gallery/nickel.jpg) nickel wishbones
![](/galpreviews/russelldouneprog.jpg) ![nemesisdoune](/gallery/russelldouneprog.jpg) nemesisdoune
alfas
posted on 24/11/14 at 08:33 AM |
thats a good advice with the clear coat...as nickel-plating is very expensive over here...and there isnt any company locally doing it...
Mr Whippy
posted on 24/11/14 at 01:03 PM |
probably better getting them chromed over brass
alfas
posted on 24/11/14 at 07:15 PM |
brought them today to my local body and spray shop....due to some corrosion underneath the oiriginal (crappy) manufacturer powdercoat the corrosion
needs to be removed before any further treatment.
as shot blasting (whatever type is used) will result in a rough surface the parts would be too rough for getting a visually nice passivated
surface....
so i decided now for powdercoat, only the screwed in wishbone eylets, some small brakcets, all bolts and washers will get passivated.
