liam.mccaffrey
| posted on 26/11/14 at 10:24 AM |
Brake Disc Dimensions
Gents I'm looking for a site where I can check the dimensions of brake discs. I need to know the inner bore diameter of the disc specifically.
You know the part which slips over the OD of the wheel hub.
I've seen any number of sites which give the disc OD and centre bore but not this dimension.
Any ideas?
In case you hadn't guessed I'm trying to find an alternative smaller disc to fit some MGZR hubs inside a 14" MX5 wheel.
Build Blog
Build Photo Album
rick1962uk
| posted on 26/11/14 at 10:39 AM |
i used EBC brakes.com
| posted on 26/11/14 at 11:10 AM |
The late 1984-1988 Rover 216 Vitesse had small diameter vented front discs that MIGHT
fit.link to disc on Brakes Int website
liam.mccaffrey
| posted on 26/11/14 at 01:27 PM |
Its the right diameter and they're only a tenner each.
I know I've seen a site which gave both the front and rear inner bore diameter just can't find it
Thanks guys
Build Blog
Build Photo Album
liam.mccaffrey
| posted on 26/11/14 at 03:56 PM |
brembo aftermarket has full dimensioned drawings of the brake discs
Build Blog
Build Photo Album
colin99999
| posted on 27/11/14 at 10:19 PM |
http://www.apecbraking.co.uk/catalogue is super useful for checking braking component dimensions
