Author: Subject: Metro MG Front uprights
wayner
posted on 8/10/02 at 02:32 PM Reply With Quote
Has anybody used the front uprights from a MG Metro, they are all ventilated discs, 4 pot calipher and a very simple upright with taper ball joint at the bottom and taper at the top.
To go even further has anyone used the complete front suspension setup in the rear of a kit car, ie antiroll bar, uprights drive shafts lower and top wishbones etc.
Any input would be kindly accepted.
theconrodkid
posted on 8/10/02 at 04:06 PM Reply With Quote
I am using escort front hubs as rears,it will give you a handbrake when you bolt on granada rear calipers,dont know bout metro setup re handbrake,as for wishbones,arb etc,im using std lower arms and arb but inboard shox at front and outboard at rear,hth
stephen_gusterson
posted on 8/10/02 at 05:29 PM Reply With Quote
I had a C reg metro turbo once - the front setup is the same as metros had as std a few years later.
BEWARE that you cant use a lower balljoint from a metro. A metro takes the load on the TOP joint. A Locost takes the load on the BOttom JOINT AND WISHBONE. The Metro one wont be used to a 'pulling' load and may pop.
You can use the front as the rear - however you will have a problem with hand brake - there wont be one - and also the steerable hubs will need tethering which is likley to give you a degree of bump steer at the rear.
Its relatively easy to hack the suspension bits - hub assby - from a sierra or granada. See my pics in the pic section for what a hacked off remounted hub is like on my unconventional rear suspension.
atb
steve
