mk85
| posted on 14/1/15 at 09:14 AM |
brake master cylinder size and pedal feal
So what size are people using for road or track and what type of feel do you get through the pedal
mark chandler
| posted on 14/1/15 at 09:21 AM |
It also depends on your pedal ratio
I am using a landrover 90 master cylinder as they are cheap new with a 4;1 ratio on the pedal
Pedal feels like a block of wood as in very little movement between light touch and stamp on the brakes, able to lock all wheels with a good hard
shove.
HTH
mk85
| posted on 14/1/15 at 09:33 AM |
I've got 4.75~1 on my brake pedal
phil clegg
| posted on 22/2/15 at 03:25 PM |
pedal
I am using the popular obp twin cylinder setup,5/1 ratio,pedal its very hard and lacks feel.i have tried variations on cylinders and different
balance,if I was building again I would try something else.can lock wheels but too much effort and need my boots on,,,,
| posted on 22/2/15 at 04:06 PM |
Tandem or balance bar ?
If tandem Rimmer Brothers are selling Girling Triumph dual circuit master cylinders on special offer or you could fit the popular Fiat cylinder.
If you have a balance bar set 0.625" & 0.7" are the usual choice
