posted on 15/1/15 at 07:49 PM |
Propshaft centre support.
Want to build a 2 stage propshaft for my 6x6 truck after seeing the setup on a ww2 American deuse and a half aka the 'jimmy'
So looking for a suitable bearing pillow block thing with a internal 6mm shaft diameter for the middle.
Was thinking of using a rose joint but will it take the rotation ok?
daviep
posted on 15/1/15 at 08:17 PM |
Is this for a model?
Why not just use a 6mm pillow block? Personally I wouldn't use a rod end.
Regards
Davie
posted on 15/1/15 at 08:34 PM |
Regards
Davie
Yep, big 6x6 out of a wheely king.. Smallest bearing block I could find was 8mm but changing my search to a 6mm internal bearing has turned up a
company called Motionco.co.uk have a bearing in a block which I've just bought. Now just need to machine a shaft to join 2 props together.
Cheers.
