Author: Subject: chassis ride height clearance
wayner
posted on 8/10/02 at 02:42 PM Reply With Quote
Is there any general consensus on how much chassis clearance to road( ie ride height ) is generally needed for road / track day locosts
JohnFol
posted on 8/10/02 at 02:44 PM Reply With Quote
As a guide, the 750 race regs state "Ground Clearance: Minimum ground clearance with the driver normally seated is 3" (75mm) excluding exhaust system and sump. Minimum ground clearance under the sump is 50mm. It is permitted to add shims to or modify the engine mountings in order to comply with these minimum heights."
locodude
posted on 8/10/02 at 05:27 PM Reply With Quote
I would say about 4-5" chassis to ground for a road car. Your sump should be no lower than 3" really, I've chopped mine (1700 x-flow)to about the level of the bellhousing and never have any grounding problems.
sting
posted on 9/10/02 at 04:41 PM Reply With Quote
160mm front and 175mm rear is w***fields guidelines
if it is of any use!
sting
interestedparty
posted on 9/10/02 at 04:53 PM Reply With Quote
sting
Do they say to what part of the chassis or running gear those distances should apply?
John
sting
posted on 9/10/02 at 05:01 PM Reply With Quote
their exact words are measured from the underside of the chassis to the ground(as in chassis rail lower to level ground.
Sting
