Author: Subject: Type 9 Gearbox Saddle
davidimurray
posted on 23/1/15 at 10:31 PM Reply With Quote
While doing my engine swap, I took the chance to swap the plastic gearbox saddle in my type 9 gearbox for a new one. The shifter is also fitted with one of the RD quick shift kits - the ones with the spacer. With the new saddle fitted, when I push the gearbox lever down, it is sticking down. A little pull gets it back up. Because the lever is cutdown, I've shortened the lever a bit to make sure the spring is compressed and it seems fine off the car.
I am guessing that once I get it in use it will loosen up a bit, was just wondering if anyone has experienced the same?
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Dusty
posted on 23/1/15 at 10:47 PM Reply With Quote
Try refitting without the saddle. Does it still stick down. Thus you will know of the saddle is at fault. Fettle the saddle if it is otherwise you may select reverse in the heat of the moment.
snapper
posted on 24/1/15 at 02:07 PM Reply With Quote
Touch of grease
I eat to survive
I drink to forget
