se7ensport
| posted on 16/2/15 at 10:36 AM |
De Dion camber amd toe shims
Hi
I have a stylus with de-dion rear suspension, having had the camber and toe checked it is out by a fair bit, where can I get shims either pre made or
custom? The wheel hubs are Sierra.
Alex
Dingz
| posted on 16/2/15 at 02:16 PM |
You have U2U
went on and on.
se7ensport
| posted on 16/2/15 at 03:24 PM |
Here is the measurements and correction details, if you spot an error in my calculations please shout, how do I convert the mm toe in to degrees
(15inch rim if it helps?):
  rear camber and toe correction
  rear camber
Dingz
| posted on 16/2/15 at 07:31 PM |
Well assuming you use 15" and 1.1mm and 3.5mm, basic trig gives the toe in corrections as 0.16° and 0.5°, similar to the camber so not much.
I'm afraid the ones I do for the std Sierra beam are more than that.
Just as a rough calc, to correct the 0.5° toe in you will need to have a difference of about 0.75mm under the wheel hubs. or .25 for the 0.16.
[Edited on 16/2/15 by Dingz]
went on and on.
se7ensport
| posted on 16/2/15 at 07:46 PM |
Dingz, thanks for the info.
| posted on 16/2/15 at 08:15 PM |
I needed to adjust the rear toe on my car and used some thin shim stock , made a cardboard template and transferred to the shim stock
