Ugg10
| posted on 27/2/15 at 10:09 PM |
brake master cylinder - numpty question
I have xr4x4 front and rear discs and calipers on escort mk2 front uprights and an english axle on my Anglia plus a Sierra inertia valve in the rear
circuit, real mongrel when it comes to running gear.
I am planning on using an mx6 tandem brake master cylinder(15/16", no servo) which has two outlets. The question is - does it matter which
outlet I connect the front/rear circuits to? I am planning on running fully braided hoses (reduces it to seven hose) and routing would be neater with
front circuit on the front outlet, any issues?
Thanks.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
JAG
| posted on 27/2/15 at 11:16 PM |
It depends upon the design of your master cylinder.
Some master cylinders have different strokes on each chamber.
Did the MX6 have drumbrakes or discs on the rear axle?
If it had discs then it won't matter - if it had drumbrakes then the chamber for the rear axle, on the master cylinder, may have shorter stroke
than the other chamber.
Justin
Ugg10
| posted on 28/2/15 at 09:10 AM |
Thanks, mx6 had discs so it looks like I can use either way round then.
Dick Axtell
| posted on 28/2/15 at 09:34 AM |
Just a thought - how are the brakes connected on the MX6? Check this out, and connect yours in similar fashion.
Ugg10
| posted on 28/2/15 at 09:40 AM |
Thanks, tried to work that out but it feeds into a rats nest of pipes in a manifold for the abs systen.
