austin man
| posted on 27/2/15 at 10:37 PM |
Master Cylinder
Hi IO currently have the standard sierra master cylinder fitted the braking effort needed is massive can anyone recommend an alternative cylinder to
replace the sierra one
adithorp
| posted on 27/2/15 at 11:14 PM |
Early mk1-2 Fiesta non-servo should be an easy swap. Done before on here with reported good results. Also some Fiat (Uno?) masters mentioned as well
Search should find the threads.
http://jpsc.org.uk/forum/
JAG
| posted on 27/2/15 at 11:19 PM |
Basically you need a smaller bore master cylinder or a larger pedal ratio.
The master cylinder that Adithorp mentions is 17.4mm bore.
[Edited on 27/2/15 by JAG]
Justin
stevem427
| posted on 28/2/15 at 12:28 AM |
Hi. Ive just had exactly the same problem on my cobra. Turned out it was the servo that was knackered. Cheers Steve.
t16turbotone
| posted on 28/2/15 at 08:03 AM |
Fiat 131 master cylinder is perfect!
