Sadsy
posted on 6/3/15 at 06:43 PM |
Rear brake setup fisher fury
I'm in need of a new setup for my fisher fury rear end, they currently have hispec 2pots but I burnt one out I actually cracked the
piston😀
I want a set of wilwoods as these hispecs are too old and hispec service is disappointing, I'm sure the running gear is escort mk2 but the
caliper mount holes match a Sierra, 13" wheels with a 256mm disc, can anyone point me in a direction to buy a kit, AB is really busy at the
moment I don't want to keep hassling him! But need brakes by next weeks ppl day at blyton!
Any ideas?
adithorp
posted on 7/3/15 at 12:27 AM |
So it's got Escort live axle (drum brakes originally) with an adapter kit to fit the discs/calipers?
You could try RallyDesign for some Wilwoods. Trouble would be matching what you already have to the Wilwoods in the time available. Think they do a
set up to convert Escort axle to disc (I think) so it might be quickest to just get that complete. It's going to be tight time wise even
then.
Alternative would be to use either the VW or Pug rear calipers but again you'd have to match up to the brackets or start from scratch.
http://jpsc.org.uk/forum/
Ugg10
posted on 7/3/15 at 07:09 AM |
Just a thought, do you have a brake balance system or an inertia valve in your brakes. Typically the rears do about 20% of the braking and also tend
to lock up if too agressive (weight transfer to the front on braking). If the caliper bracket is a bolt on then why not swap for one of the Sierra
csliper based kits, or there are others out there using the ally vw calipers.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
adithorp
posted on 7/3/15 at 08:56 AM |
Worth noting that people have reported issues with Hi-Spec calipers; Binding, leaking and moans about poor aftersales support.
Oddified
posted on 7/3/15 at 09:03 AM |
Plenty of kits around to fit the sierra/granada rear calipers to an english/atlas axle such as;-
http://www.ebay.co.uk/itm/Capri-Escort-13-solid-rear-disc-conversion-kit-/221642721497?pt=LH_DefaultDomain_3&hash=item339aef88d9
Rally design do do kits for back axles, or they also have quite good drawings of the wilwood calipers so you might be able to find some calipers that
will fit straight onto your current brackets/disc's with none or small mods/spacers needed.
Ian
[Edited on 7/3/15 by Oddified]
Ugg10
posted on 7/3/15 at 09:27 AM |
The link Oddified has posted is a Caprisport kit http://www.zyworld.com/caprisport/1_brakes.htm , they do a wide range of different calliper/disc
combinations. But you need to check that your English axle fits their kit, they are designed for the Capri axle, my Anglia axle did not and I had to
do quite a bit of faffing to get it to fit (not Caprisports fault). That said, easy fit, I managed to make mine fit with standard sierra solid discs
(253mm) and XR4x4 callipers therefore no axle flange machining needed. I have paired mine with the Caprisport GTR260 front brakes and a sierra inertia
valve so basically an XR4x4 full set up (on an Anglia).
If you want to go down the OEM calliper route others to look at are -
Mk2 Mania - http://leonbirchall.co.uk/index.html they also sell on ebay
Arrow engineering (they do the VW caliper version) - http://www.arrowautoengineering.co.uk/page5.htm
[Edited on 7/3/15 by Ugg10]
lsdweb
posted on 7/3/15 at 09:49 AM |
I've just finished my rear caliper conversion using Peugeot calipers - these are the same as the Renault and Citroen ones so loads out
there.
These fit nicely under 13" wheels
I can get a set of brackets made for you if you wanted.
Sadsy
posted on 7/3/15 at 11:20 AM |
Cheers for the replies, yes the hi spec after sales is crap! I've been looking at these as I want to redo the back end, this is a full kit but
radial mounted, I have Ali brackets already from the hispec ones they look like a crows foot shape, I'm hoping these won't take much to
fit I've looked at all the measurements like caliper dimensions which are the same as the hispec, discs are the same too......
Escort RS Donor - Powerlite - 265mm Solid Kit
Click to enlarge
A new range of braking kits designed utilising the new lightweight Powerlite caliper and a 265mm solid brake disc. These kits are suitable for kit
cars and smaller formula cars where lightweight is so critical. (kits suit most 13" wheels).
£266.20
Available Options:
Style of disc:
Sadsy
posted on 7/3/15 at 11:55 AM |
I'm going to try some escort rs2000 rear calipers as I'm unsure of all the brake packages and Im not sure of my axle etc.... I can't
add any pics on here but have a few if anybody could tell me how to upload them? The bolt holes in these calipers match the hispec ones so worth a
shot before I buy a full kit. I have a brake bias adjuster so can tweek it once they're on
