OliilO
posted on 26/3/15 at 06:01 PM |
Sierra CV Joint Boots
I need to replace the inner and outer CV joint boots on my car as they are beginning to perish slightly and I'd rather do it now than mid
summer. Unfortunately, I'm not with the car currently, so would anyone be able to point me at the appropriate boot replacement kit as I am
unable to look at the existing ones and eBay seems to have a multitude of options.
It's a 7" 3.62 sierra LSD with bolt on driveshafts, but haven't the foggiest which Sierra models it was originally used in...
Thanks.
Oli
CosKev3
posted on 26/3/15 at 08:20 PM |
I bought some universal ones you cut down from my local motor factors, recommended as they are the stretchy type you can fit without removing
joint.
Just took a old boot with me to compare sizes
loggyboy
posted on 26/3/15 at 08:22 PM |
Only 2 versions im aware of, (for bolt on's) 100mm or 108mm, Most likely they are 100mm, but would need to measure.
[Edited on 26-3-15 by loggyboy]
Mistral Motorsport
CosKev3
posted on 26/3/15 at 08:23 PM |
[Edited on 26/3/15 by CosKev3]
ianhurley20
posted on 26/3/15 at 10:09 PM |
I used universal ones off ebay that came with a cone and lube for about £5 each inc postage - worked fine
DJT
posted on 27/3/15 at 07:41 PM |
^ +1
http://tigeravonbuilddiary.blogspot.com/
