ceebmoj
| posted on 26/3/15 at 07:35 PM |
gear box and diff dimentions for prop shaft
Im just about to put the order for my prop shaft together. So does anybody know the following information?
* The size and number of the splines on a type nine out put shaft
* The PCD and bolt size on a ford sierra LSD with bolt on drive shafts
thanks for the help
ceebmoj
| posted on 26/3/15 at 09:15 PM |
The bailey morris specification drawing indicates
35mm dia * 25 teeth for the gear box spline.
109mm, 4 bolt 10.1 90mm PCD Axle flange.
Does any one know if this is correct?
Dingz
| posted on 26/3/15 at 11:31 PM |
Measured one recently and they are 25 splines, shaft od 34.9. don't know about the diff end though. But when I got my prop from Bailey I just
told them what I had and length, they did the rest very quickly, well made, driveshafts of all types is what they make.
went on and on.
