generaldogsbody
| posted on 2/4/15 at 10:45 PM |
clunking noise
Hello everyone i am new to this forum,i am on a low budget so i hope someone can help.I bought a mk2 1990 sierra p100,with the intention of doing it
up a bit.When i brake it pulls to the right,i thought it might be a brake caliper sticking.I found out when i was stuck in traffic,if i move off
slowly and touch the brake pedal there is a clunk from the n/s front wheel,I put it in reverse and moved off slowly touched the brake pedal,it did the
same clunk from the n/s front wheel.It would help if i knew what to look for when i jack it up,Does any one know what to look for.All advice
welcome.Thanks in advance.
bi22le
| posted on 2/4/15 at 10:54 PM |
Does it only clunk once at a time or with every wheel resolution or pedal push?
Look for something loose!
Give everything a good push pull on that corner and user a crow bar to check the bushes.
Please read my ring story:
generaldogsbody
| posted on 2/4/15 at 11:15 PM |
it clunks every time i touch the brake,and seems to shove the steering to the right.ps good ring story.
mark chandler
| posted on 2/4/15 at 11:37 PM |
Remove wheel, look at he brake pads, pulling to the right o/s could be worn out pads on the left n/s.
Are there rusty filings on the wheels, another sign of shagged pads, check the discs, if badly scored they need replacing.
Given that for £100 you can replace most pads and discs these days if in doubt chuck the old stuff away, get Mintex pads (1144) discs and feel the
improvement, while apart work the caliper Pistons to make sure they move smoothly without binding.
If you do not understand this then find someone who does and get them to. show you what they are doing, you only get one chance with brakes usually.
19sac65
| posted on 3/4/15 at 01:24 AM |
I dont know if the P100 is different to the saloon but they used to eat their compliance bushes
Its the bush on the bottom arm where the antiroll bar passes through
Get someone to drive the car at a snails pace,stabbing the brakes
Look at the front wheels side on , you'll see The faulty one moving backwards when they brake
They were cheap and easy to replace
| posted on 3/4/15 at 07:07 AM |
Another vote for compliance bushed, if they have failed try to get a set of updated bushes from a motor factor , the Ford bushes were rubbish even
when new
generaldogsbody
| posted on 3/4/15 at 01:44 PM |
Yes that sounds about right,am on it.Thanks for your replys.
adithorp
| posted on 3/4/15 at 03:27 PM |
Sounds about right. Fitted thousands back in the day.
We found (because some customers wanted things to feel a bit stiffer) that flattening (a bit) the big washers each side of the bushes, made a huge
difference to the feel and longevity of the bushes. We used to just squish the dishing by about 50% in the vice. Do it bit by bit, rotating the washer
as you go to keep it symmetrical.
http://jpsc.org.uk/forum/
generaldogsbody
| posted on 3/4/15 at 05:55 PM |
What i ment to say was,the information you gave me sounds good.Just glad it's not gonna cost a fortune to put right,and thanks again for all
replies.
