Hodor
| posted on 4/5/15 at 10:24 PM |
Help identifying these wishbones
Hello. I've got these top wishbones to give me greater caster angle on my MK Indy. They came as spare bits with the car.
Problem is I only have one insert to screw the transit ball joint in to, and one bush set with crush tube. Rest of them are missing.
  indy top wishbones
Question I have is can anyone help me identify their parentage so I can track down the other insert I need (or get steel ones made) and new PU
bushes?
Measuring the OD of the mounts of the wishbones that are on the car currently, these new ones are a couple of mm bigger, so I suspect that the inserts
and bushes of the current wishbone won't fit.
Cheers.
wylliezx9r
| posted on 5/5/15 at 07:02 AM |
This may be the camber adjuster you require eBay Item
George Best
Hodor
| posted on 5/5/15 at 07:17 AM |
Cool, thanks. I'll contact him for a drawing. Cheers.
mark chandler
| posted on 5/5/15 at 07:26 PM |
They are big old things, I would contact McGill motor sports and purchase 4 x 1/2" UNF Rose joints with lock nuts and pre-thread sleeves, cut
the ends off and weld in the sleeves and have it fully adjustable for a few £££
You can then set the caster to suit yourself and optimise the handling.
