liam.mccaffrey
| posted on 6/5/15 at 01:15 PM |
Suspension Brackets
Does the standard "book" brackets (either champion or Gibbs) have a 1/2" bolt hole anyone know.
Alternatively does anyone sell brackets with 1/2" bolt holes off the shelf.
Build Blog
Build Photo Album
Slimy38
| posted on 6/5/15 at 01:45 PM |
I would highly recommend Dave at Rogue engineering;
http://www.ebay.co.uk/usr/daveo1121?_trksid=p2047675.l2559
I got my brackets from him and he seems quite receptive to customizations. Very good prices too.
joneh
| posted on 6/5/15 at 05:28 PM |
2nd for Dave. It's where I got mine from and the chassis plates.
If your holes are M12 it's worth getting a reamer to match the bushes. I had to ream all my fury chassis holes to match the bushes.
baz-R
| posted on 6/5/15 at 06:00 PM |
haynes roadster aka gibbs have 12.5mm holes iirc a champion orignal locost didnt tel you what size just put an 8mm pilot hole and then drill out to
size?
| posted on 6/5/15 at 08:30 PM |
Im going to build mine and weld a 12mm stainless washer on the outside then ream the hole with the correct size reamer once welded on the chassis.
joneh
| posted on 6/5/15 at 09:07 PM |
I should point out that I reamed the fury chassis, the Haynes brackets for the roadster from Dave are fine!
