ianhurley20
| posted on 29/5/15 at 11:10 AM |
Mazda Mk 1 & 2 sterring wheel boss
I'm building a Haynes Sierra/MX5 Roadster with a Mazda MX 5 1.6 Mk 2 steering column. I bought a steering wheel and boss from ebay which had
been fitted to a 1.8 Mk 1. Ok I knew there would be issues with the airbag and horn but I was surprised to find the splines on my Mk 2 column are
about 15mm dia where the boss I have bought is about 25mm. Looking around many suppliers say a Mk 1 boss will fit a Mk 2 but with no airbag or horn
connections.
Does anyone know what the column diameters are on the various models - or have a boss that will fit my Mk 2 - I don't want to buy a Mk 1 boss to
find it will not fit again.
Ian
ianhurley20
| posted on 4/6/15 at 07:54 AM |
I guess no one knows so I bought a Mk 1 boss and yes it fits the Mk 2 fine. Airbag and horn connections don't work and you may need to drill two
7mm holes to match the prongs for indicator cancelling. As I don't have a screen I am using the screenwash stalk function for the horn.
Angel Acevedo
| posted on 4/6/15 at 11:22 AM |
IIRC You may need to put a Horn Icon for IVA.
Someone with greater knowledge will confirm (or deny) shortly.
ianhurley20
| posted on 4/6/15 at 12:01 PM |
I expected that would be the case, haven't done it yet but its on the massive 'to do' list, thanks
