John G
| posted on 31/5/15 at 02:12 PM |
fabricating plate to hold mechanical handbrake caliper
I need to fabricate a plate to hold my wildwood mechanical handbrake calliper to the hub. Any recommendations on thickness of material, alloy or
steel?
Any supplier of alloy or steel plates?
Does anyone know of a suitable supplier or a company that could CNC cut a set of plates to my design?
Regards, John.
| posted on 31/5/15 at 02:28 PM |
Doesn't the rally design website have a diagram with the sizes and some blank or bespoke brackets to help?
theprisioner
| posted on 31/5/15 at 02:58 PM |
The plates on my Sylva are about 6mm (I can measure them), they are fabricated steel. There are lots of on line cnc plasma cutting services these
days. You just send them a .dfx file from a drawing package and back comes the goodies. Then just weld them in place.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
John G
| posted on 31/5/15 at 03:09 PM |
Thanks for the heads up, I've had a look and the bracket would need a lot of cutting to sit round the hub. I am after a flat plate with a fairly
complex shape to join the two together so probably something cut with a water jet or plasma cutter. Still making up card templates to work it all
out.
Regards, John
Kdempsie
| posted on 31/5/15 at 03:12 PM |
I did these brackets for mine, shown on a club blog
https://jpsc.org.uk/forum/viewtopic.php?t=1209&start=10
Keith.
