Rosco86
| posted on 22/6/15 at 07:34 AM |
Haynes Shaft Length
Im trying to sort some drive shafts for my haynes roadster, ive made the wishbones to the correct length to take standard wishbones
i have a distance when level between the flanges of 490mm and 450mm (100mm bolt on shafts)
the shaft lengths is can find are
520mm
466mm
480mm
508mm
anyone have any ideas?
big_wasa
| posted on 22/6/15 at 12:22 PM |
From memory there was a cock up on the first edition book. I think you will end up making a set of bones 10mm or so longer or custom shafts.
loggyboy
| posted on 22/6/15 at 12:29 PM |
I may have set of spacers that could help you.
They fit between hub/upright and bearing carrier. I think you will need to use use push-in shafts as the bolt on stub axle may clash with inner
diameter of the spacer.
I had them made up for another reason, to use drums on my striker so the back plates missed the upright, but decided to go with discs instead.
Mistral Motorsport
MikeR
| posted on 22/6/15 at 06:58 PM |
If the OP doesn't want them I could be interested. Could you message me the details?
Rosco86
| posted on 22/6/15 at 07:48 PM |
The wishbones are correct as I've remade them already
Rosco86
| posted on 22/6/15 at 07:49 PM |
That's an idea, I think I will be ok but it's a good plan if the shafts bind, just make some aluminium spacers! Cheers
Rosco86
Feel free mate
