Lander
posted on 3/7/15 at 05:10 PM |
Wheel Spacers
If I were to have some wheels that needed approx. 20mm spacers are there any problems or things I should be aware of ?
Thanks,
Ian
Paul AS
posted on 3/7/15 at 09:09 PM |
Just make sure you get hubcentric spacers and youve fitted extended studs/bolts accordingly. I ran them for two years front and back and on track days
with no issues. If you've got Ford fittings, I've got a pair of 16mm 4x108 with 63.4mm centre bore.
daniel mason
posted on 3/7/15 at 09:18 PM |
One of my old radical race cars ran a spacer on the fronts to clear the calipers,with no issues at all
rodgling
posted on 3/7/15 at 09:34 PM |
I have 25mm spacers at the rear, no issues. You may find you go through wheel bearings a bit quicker though (I had to replace one recently, maybe
related, maybe not).
Lander
posted on 4/7/15 at 07:57 AM |
Great Thanks guys
thefreak
posted on 4/7/15 at 12:33 PM |
Drop me a u2u if you want a set making. We custom make bolt on wheel spacers (and slot on) to your specs. Can make them with different inner and outer
centre bores and PCDs if needed. Www.freakyparts.co.uk for examples
