dilley
posted on 9/7/15 at 06:28 PM |
Lobro shafts
I need to cut an join s2000 shafts to lobro shafts, are lobro shafts identical either end? Bottom line is can I use one drive shaft and make two.
Dilley
minitici
posted on 9/7/15 at 07:07 PM |
Yes - same splines both ends.
25 spline on 100mm Lobros and 28 spline on 108mm Lobros (Ford)
Or 33 spline on VW 100mm & 94mm Lobros
dilley
posted on 9/7/15 at 07:09 PM |
Ok, what about without end shafts, cv's, the bolt on part either end!
I have 1 shaft minus the stubs....
[Edited on 9/7/15 by dilley]
mcerd1
posted on 9/7/15 at 11:02 PM |
The CV's for each end are identical - they are just fitted facing the opposite direction
Just be aware that any hybrid shaft will wear out the CV's a bit faster (due to the imbalanced forces acting on it without the matching CV on
the other end)
[Edited on 9/7/2015 by mcerd1]
