OliilO
posted on 12/7/15 at 02:55 PM |
Stiff new wheel bearing
At the end of my last track day I developed a bit of a vibration that got worse towards the end. On inspection the rear right disc and bearing carrier
were much hotter than the other side, so I did a bit of digging when I got home. The rear hub was stiff and wouldn't spin freely even with the
driveshaft and calliper removed so I ordered a bearing from Burton power and replaced it. I also cleaned up all the pad carrier and slide pins on the
calliper incase the calliper had been sticking a bit.
After about a hundred miles on the road there still feels like some vibration is there. The disc was still slightly warm as well. Stripping that side
down again, the new bearing still feels quite stiff and graunchy. What's the most likely cause of this? A few things I thought of were;
a) over torqued it, causing it to bind slightly
b) it needs to do a few more miles to loosen up a bit
c) knackered the new bearing with the sticky calliper heating it up
d) something else...
mark chandler
posted on 12/7/15 at 03:42 PM |
It's a High torque on Sierra rear wheel bearings as the races are a machined fit, when new they are indeed stiff for the first few hundred
miles.
Graunchy does not sound good knock off the halfshaft to make sure it's not something further back in the drive line.
OliilO
posted on 12/7/15 at 03:52 PM |
I've taken the drive shaft and calliper off. It's definitely the bearing that is stiff.
mark chandler
posted on 12/7/15 at 04:13 PM |
Go with b)
It will sort itself out, my new bearings were very stiff when replaced.
posted on 12/7/15 at 07:12 PM |
If the car has a viscous LSD you need to have both wheels off the deck and out of gear before you check for free rotation,
It sounds more like the original problem was brake related.
Ben_Copeland
posted on 12/7/15 at 07:24 PM |
He disconnected the driveshaft so it won't be that.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Ben_Copeland
posted on 12/7/15 at 07:25 PM |
Give it a few more trips out and see if the bearing frees off
Ben
Roadster
OliilO
posted on 17/7/15 at 05:48 PM |
Had another look at it this afternoon and it felt very 'notchy' when rotated, almost as if I could feel the individual rollers moving.
So I've stripped it out and will hopefully have a new one to put in tomorrow. The grease smelt pretty horrible, so wonder if the brake has still
been dragging a bit and heated the hub up enough to knacker the bearing.
posted on 17/7/15 at 06:07 PM |
How did you press the new bearing in? If you pressed on the inner race there is a chance you damaged one of the races, bearings should be pressed in
by pressing on the outer race
OliilO
posted on 17/7/15 at 06:42 PM |
I used the old race as a drift, so perhaps not ideal. Might be worth trying to get this one pressed in?
It didn't feel bad initially, just a bit stiff, hence my thoughts that it might have been heat causing the issue.
Bluemoon
posted on 17/7/15 at 09:18 PM |
may be worth checking the seat the bearing is pressed into making sure it is clean. The preload is set buy these clearances a bit of crap/rust might
be enough to set to high a preload knackering the bearing.
Dan
OliilO
posted on 18/7/15 at 06:44 PM |
Right, so I've got he he new bearing in and it feels much better. I think I probably put a bit too much grease in the last one (compared to the
supplied packet of grease I used today) which may not have helped matters. Also cleaned up all the calliper slider pins and the channels the pads sit
in to rectify any brake drag. I'll see what happens tomorrow if it's dry...
OliilO
posted on 24/7/15 at 08:41 PM |
After a mile, I had a quick check that everything looked fine and found the rear disc was still excessively hot. So that'll be what knackered
the bearing then. Time to rebuild the calliper tomorrow and see how that goes.
