Jeffers_S13
| posted on 6/12/04 at 03:43 PM |
Clutch fluid level sensor
Do I need a clutch fluid level sensor in the same sense as I need the brake fluid level sensor for SVA ? Anyone with hydraulic clutch passed without
one ?
Im thinking of using a three way reservoir with integral level sensor from car builder solutions, and get three master cylinders without reservoirs.
The thing is I already have three brand new master cylinders with their own integral tanks how annoying...
Anyone have any other suggestions ?
James
ned
| posted on 6/12/04 at 03:46 PM |
good point, though the hydraulic clutch pedal box i bought doesn't have a sensor on the resovoir it came with. i think it's only the
brakes but am happy to be wrong..
Ned.
beware, I've got yellow skin
| posted on 6/12/04 at 03:50 PM |
Don't worry about it.
You'll know when the fluids gone. It's not a requirement if that's what you mean and if you do have one don't link it to the
brake warning light.
Jeffers_S13
| posted on 6/12/04 at 03:56 PM |
So would it be a fail if I had it connected to the same resevoir as the brakes you think ? I cant see it doing any harm.
Or rather than getting a three way resevoir and blocking off the third exit (will look odd), do you know where I can get a twin exit one ? DAX as
usual want something daft like £65 plus VAT for theirs...
Oh, and a cheap supply of reservoir-less cylinders would be useful aswell ! or its another £56 plus P+P from car builder solutions place.
James
ned
| posted on 6/12/04 at 04:14 PM |
resovoir less cylinders?
my twin brake bias box resovoir from luego has two outlets only, the clutch is a seperate resovoir..
Ned.
[Edited on 6/12/04 by ned]
Jeffers_S13
| posted on 6/12/04 at 04:19 PM |
Sorry I meant integral reservoir less cylinders. If you look here :
http://www.nfauto.co.uk/master_cylinders.htm
I will need two of the top ones. I currently have three of the bottom ones.
How much are the twin exit reservoirs from Luego ?
James
ned
| posted on 6/12/04 at 04:31 PM |
not sure how much as i bought a complete pedal box which they ere part of, their website might say, otherwise just give em a ring..
Ned.
jollygreengiant
| posted on 6/12/04 at 08:03 PM |
Most of the big manufacturers already have provision for single fluid reservoirs on their production cars (brake and clutch from one reservoir.) all
you need to do is to look closely at the mastercylinders and look for an extra fluid out/of pipe (used for clutch OR sealed for cable opperation or
automatic box).
Enjoy
