Author: Subject: Westfield - Locost wishbones, are the same?
tajgreidotu
posted on 24/7/15 at 10:28 AM Reply With Quote
Im looking to buy a set of front wishbones, I found some cheap Westfield wishbones, and I wonder if they are valid or not?
My chassis is Locost book, and I ill make the suspension brackets once I have the wishbones. Sierra front Uprights.
Thanks!
dilley
posted on 24/7/15 at 11:08 AM Reply With Quote
Hi, I have a full set of used front and rear wishbones that use Sierra components. These were fitted to an mk Indy.
kingster996
posted on 24/7/15 at 12:20 PM Reply With Quote
Originally posted by tajgreidotu
Thanks!
Only Westfield Sierra SDV wishbones will fit the Sierra uprights - all others (apart from Mazda SDV) use Cortina geometry.
No idea if the chassis mountings will match (even if you can place them) but doubt it.
[Edited on 24/7/15 by kingster996]
I used to be indecisive, but now I'm not so sure
