Lander
| posted on 30/8/15 at 05:03 PM |
Brake Flexis
Hi All,
I am at the point that I need to purchase the flexible brake hoses that go from chassis to calipers/drums at all 4 corners. What lengths are the
flexis that I need. Tiger Avon if that is relevant.
Ian
Lander
| posted on 2/9/15 at 07:23 PM |
Anyone?
nickm
| posted on 5/9/15 at 07:05 PM |
Hi
You just need to measure the distances from end of your solid pipe to where they fit the caliper but allow a bit extra for the suspension movement.
They shouldnt touch anything on the run so be carefull at the front with full steering lock etc. It will be a bit of a guestimate i find if you use a
bit of flexible rubber pipe or electric wire it represents the braided pipe run better than limp string.
Hope this helps
Nick M
Lander
| posted on 5/9/15 at 08:22 PM |
Thanks Nick,
I have taken a guesstimate today so fingers crossed.
Angel Acevedo
| posted on 6/9/15 at 06:15 PM |
There´s some flexi and fittings on the "For Sale" Section.
http://www.locostbuilders.co.uk/viewthread.php?tid=200141
3 mt should suffice.
Lander
| posted on 6/9/15 at 06:51 PM |
Thanks.
