micksalt
posted on 11/9/15 at 07:51 AM |
Replacing MX-5 CV Joints: A Word of Caution
If, like me, you damage the end of the outer CV joint trying to free it from the splines of the hub, chances are that you'll need a new CV
joint. The good news is that they're pretty cheap (£32 a pair for me), and easy to remove (take off gaiter, hit with hammer from the back). The
bad news is that there are two variants of driveshaft, ones with a 22-spline end, and others with a 30-spline end (credit to sdh2903 for this
information). Remove your CV joint first and count your driveshaft splines before you order, or else you may well end up with the wrong one. It seems
that the splines to the hub are all the same at 26 splines, so it's just the inner part of the outboard CV joint that you have to worry
about.
Which brings me onto a question, where are people finding the 22 driveshaft-spline outer CV joints? I can find ones with ABS, but not without, but
does that matter, will they both fit?
[Edited on 11/9/2015 by micksalt]
sdh2903
posted on 11/9/15 at 08:54 AM |
Doesn't matter. As long as the splines are correct the abs side of things doesn't affect them.
Got mine from J and R driveshafts. 30 of quid for a pair with a 2 year warranty.
micksalt
posted on 11/9/15 at 09:25 AM |
Thanks for that, do you know if you can knock the ABS reluctor rings off? I'm thinking weight saving, rotational mass reduction, unsprung weight
reduction and removing a muck trap. Obviously it'll invalidate the warranty but the cost of the parts relative to effort it would take to remove
the part wouldn't make the warranty that valuable anyway.
posted on 11/9/15 at 09:27 AM |
Thanks. Can you explain how the CV joint comes off the stub axle? Not just press fit is it?
My upright has been soaking in penetrating oil for about 4 months now and my next attempt is going to be welding up a jig to hold it and a 20 ton
bottle jack to see if I can get to out.
It would be nice to remove the shaft to make this a bit easier, so far I've removed the gaiter, released the outer circlip but its still tight
in there...
I may have to source a new upright without the shaft in it!
DW100
posted on 11/9/15 at 09:29 AM |
Normally the abs rings are just a shrink/press fit and would knock off.
But it'll only be a few grammes
micksalt
posted on 11/9/15 at 09:41 AM |
Coozer,
The CV joint is held onto the driveshaft just by friction, and being that this area is soaked in grease, it shouldn't be seized. I cut off the
tabs to the boot, peeled the boot back and then secured the driveshaft in a vice, I then hit the inner part of the CV joint, being careful not to
contact the driveshaft and it came off with not too much effort. Since you have the weight of the hub and upright still attached to the end of your CV
joint, I'd tie them all to something so when it does come off, it won't land on your toe.
As for getting the CV joint out of the hub and thus freeing your upright, it sounds like yours is as bad, if not worse than mine was, The solution was
the biggest oxy-acetylene torch we could find to get the hub white-hot and thus greatly expanded, then just hammer on the end of the driveshaft whilst
supporting the whole assembly in a heavy-duty jig:
BigJig
Yes, the CV joint will need replacing after all this and the bearings, but as long as the hub is allowed to cool naturally (rather than being
quenched), I'm reliably informed that it shouldn't harden too much. You do need the proper oxy gear though, the medium-sized torch
couldn't rouch it, so I can safely say that any propane-powered lamp wouldn't have even tickled it.
