Author: Subject: Wheel bearing differences
phoenix70
posted on 11/12/04 at 07:05 PM Reply With Quote
Hi All,
Just wondered why ABS makes a difference on the wheel bearings. I've got a LSD + shafts off a ABS equipped sierra, but the hub carriers are off a non abs car, so I'm not sure what wheel bearings to buy, or am I up a certain creek without a paddle.
TIA.
Stu16v
posted on 11/12/04 at 09:18 PM Reply With Quote
Are there different bearings listed for ABS/non ABS?
jollygreengiant
posted on 12/12/04 at 10:50 AM Reply With Quote
Toothed rings for the ABS pick up, would be the cause of the difference, cos they fit inside the hub in the bearing set. Get excessive grease in the bearings when you rebuild and the ABS lamp comes on because of grease in the slots.
Enjoy.
[Edited on 12/12/04 by jollygreengiant]
zetec
posted on 12/12/04 at 11:36 AM Reply With Quote
Yep, and if I remember correct ABS bearing is about double £££s at something like £45! That said they don't normally need changing.
phoenix70
posted on 12/12/04 at 06:54 PM Reply With Quote
Enjoy.
Does anyone know if this is the only difference, as one of the things I've got to do is remove the Toothed ring (won't fit the Indy Uprights)
James
posted on 14/12/04 at 12:02 PM Reply With Quote
You can get them on ebay- Bob managed a set for 9quid or something.
Also, someone recently said that Halfords were selling off their stock cheap.
HTH,
James
