Author: Subject: Front Hubs - Cortina / Sierra
Avoneer
posted on 13/12/04 at 05:10 PM Reply With Quote
As I intend to fit Sierra front uprights to my book chassis and book wishbones, will all the angles still be ok?
I am under the impression that all will be the same if I use the insert thing for the top ball joint, all be it sticking out a bit further on each side due to the width of the Sierra hub compared to the Cortina one.
Pat...
posted on 13/12/04 at 05:29 PM Reply With Quote
Are you altering the front track to Sierra width? Book top wishbones look like they will give too much positive camber with standard bottom wishbones. You could shorten the top ones or lengthen the bottom, which seems a better idea. Anybody done it already?
Avoneer
posted on 13/12/04 at 05:32 PM Reply With Quote
Using standard Sierra rear track and whatever will fit at the front.
Looking at it from above, won't the ball joints be in the same plane as the Sierra ones? Isn't it just the hub that sticks out more?
Pat...
James
Sorry mate, you can't just fit Sierra uprights to Cortina (book) wishbones- even with top adapter. The BJ holes are in different places- meaning your wishbones will be out.
Darren of GTS put some pictures up recently of the result of having done this (or maybe it was Cortina hubs onto Sierra length wishbones!) but the point is it was completely out.
I'd go with Cortina hubs (lighter anyway) as otherwise I suspect your geometry will be all over the place.
Hope that helps, I'm not 100% about all that but pretty sure.
James
Avoneer
posted on 13/12/04 at 05:35 PM Reply With Quote
Boll*x.
Got some Mk2 Escort uprights, some Sierra uprights and standard book bones!
What's gona work out cheapest?
Pat...
Northy
posted on 13/12/04 at 06:19 PM Reply With Quote
I'd go for Cortina. I might know where there are a pair of uprights and calipers cheap.
What you using at the back?
Graham
Avoneer
posted on 13/12/04 at 06:32 PM Reply With Quote
Hi G,
Yes - would be very interested.
Using one of my spare LSD's and full 4x4 rear end for the back with the GTS de-dion bar.
Pat...
Avoneer
posted on 13/12/04 at 06:46 PM Reply With Quote
Then again, it may be easier for me to use the wide track front end from GTS or MK as I like the stance you get.
Are the MK and GTS bones designed for Sierra uprights?
Pat...
Northy
posted on 13/12/04 at 07:17 PM Reply With Quote
Well let me know, otherwise I'll have the tw*ting things!
Graham
Avoneer
posted on 13/12/04 at 07:35 PM Reply With Quote
How much?
Got to way up a set of new wide track bones against the uprights and new discs etc.
Pat...
Northy
posted on 13/12/04 at 08:25 PM Reply With Quote
U2U sent
Graham
Avoneer
posted on 13/12/04 at 08:41 PM Reply With Quote
U2U sent back...
Great this isn't it - keep everyone guessing!
Pat...
Northy
posted on 13/12/04 at 08:43 PM Reply With Quote
U2U sent back to you again.....
Graham
Avoneer
posted on 13/12/04 at 08:52 PM Reply With Quote
And again.
Anyone for tennis???
Doubles???
(Max and Paddy)
Pat...
Northy
posted on 13/12/04 at 08:54 PM Reply With Quote
Job done. Another happy customer, and two more pints in my beer fund!
G
Graham
James
posted on 14/12/04 at 12:12 PM Reply With Quote
Pat...
In case anyone's bored of tennis and wants to know the answer to this then yes- the MK Indy and the GTS wide-track wishbones are designed for Sierra uprights.
HTH,
James
Avoneer
posted on 14/12/04 at 01:57 PM Reply With Quote
Cheers James.
That's all I wanted to know.
Pat...
