Nickp
| posted on 12/12/15 at 09:49 AM |
BMW - Ford prop adapter?
Ok, so I'll be dropping my engine/box in soon to measure up for the prop.
My BMW gearbox o/p is a 3 bolt flange which normally has a rubber do-nut attached. My idea was to replace this do-nut with a steel adapter so that a
Ford Sierra UJ would bolt to so I can simply get a Ford UJ - UJ prop made up to length. I thought I'd keep it the same size as the original
do-nut so I could use the BMW bolts and keep it all simple. So I got a local firm to make me a 'blank' so I could mark up and drill the
holes myself. But now I've got this 115 wide x 32mm deep behemouth in my hand I'm seriously worried about the weight!! The thing currently
weighs 2.4kg!! Once I've drilled the holes I'm thinking of taking it back and getting them to take it down to around 10-15mm thick.
I'm worried about the load on the gearbox bearing and the balance of the thing too. If I take it down to 10mm would that leave me enough thread
for the 3 x M12 bolts after I've tapped the holes? Or should I get the whole thing remade in alloy instead maybe?
Long bolts are only to check alignment to Ford UJ-
Thoughts please.
[Edited on 12/12/15 by Nickp]
hizzi
| posted on 12/12/15 at 10:30 AM |
i would use the bmw end at the gearbox and the ford end at the diff and make the transition in tube, that means both couplings are standard of the
shelf items
Nickp
| posted on 12/12/15 at 11:36 AM |
I asked on here about doing that way ie donut front uj rear but the general consensus was that it wasnt such a good idea as the 2 flanges will be
offset slightly and a donut's meant to run straight (to a centre bearing).
hizzi
| posted on 12/12/15 at 03:17 PM |
yep rubber couplings dont like being offset. i use them on landrovers and they are a pain, you can buy a kit to remove them on discoverys etc any
chance someone does a replacement flange for the bmw?
another though what about welding up the holes on the ford prop then redrilling to match the bmw
Badger_McLetcher
| posted on 14/12/15 at 11:46 PM |
I ended up getting North West props to make me a Jag - Sierra propshaft; they'd be able to do the same for you as the gearbox is exactly the
same. That way no worries about spacer plates etc.
If disfunction is a function, then I must be some kind of genius.
907
| posted on 15/12/15 at 02:36 AM |
I have an XJ6 prop, as it fits the Getrag box, that fits my Lotus engine. ( Sounds a bit leg bone connected to the knee bone )
I made an adapter plate the other end to fit the Jag flange onto the Sierra dif.
Its normally accepted engineering wise that if your tapping M12 you would finish machining at 12mm thick.
I machined the centre out of mine as this doesn't contribute to strength, but left a slight shoulder so that it centralised itself.
I also marked the PCD's while the piece was still in the lathe to keep the studs concentric.
HTH
Paul G
Nickp
| posted on 15/12/15 at 06:43 AM |
HTH
Paul G
So are you donut front / UJ rear then?
Nickp
Got any pics mate?
907
| posted on 15/12/15 at 08:50 AM |
HTH
Paul G
No, U/J's both ends, the sort that have replaceable bearings held in with circlips
Paul G
Nickp
| posted on 15/12/15 at 09:03 AM |
HTH
Paul G
Paul G
Ok, but the ones I've seen on ebay seem to be donut front like in the BMW-
JAGUAR XJ6 X350 PROP SHAFT
Badger_McLetcher
| posted on 15/12/15 at 06:50 PM |
Got any pics mate?
I thought I had some better one's but apparently not:
It's got a BMW\Jag front, sliding section and a sierra rear. They did a good job as well from the looks of it
If you want better pics or of a specific bit I can try to grab you some this weekend.
Nickp
| posted on 15/12/15 at 07:09 PM |
This is pretty much what I'm attempting to make. Looks like it fits both sizes of BMW 3 bolt o/p flange, my 323i one and the slightly larger
328i one. I'm thinking of reproducing what I've already got but in alloy instead and only 20mm thick. I might also drill it for the bigger
flange too in case I need to swap the box at any point-
http://www.driveshaftshop.com/import-driveshafts/bmw/conversion-plates-93-98-supra-rear-converts-3-finger-to-1350-flange
I've just been quoted £125+vat for a Sierra UJ-UJ prop with larger HD 3000 series UJs.
Badger_McLetcher
| posted on 15/12/15 at 08:55 PM |
I did look at those then just thought it would be easier to get a fully unified propshaft; one less bolted joint to worry about!
Just for reference mine was £175 +vat +delivery.
