locost7-online.com
posted on 27/12/15 at 07:57 PM |
Which master cylinder to use?
What's the reccomended master cylinder setup on a tiger Avon / Haynes roadster?
Not looking for a bias setup it's initially just a road car
Locost Xflow 150bhp injected! Sold :-(
Facebook blog https://www.facebook.com/Johns-Tiger-Avon-Build-814223212056368/
PLEASE NOTE THIS MEMBER IS NOT A TRADER.
garyt
posted on 27/12/15 at 08:09 PM |
fwiw, On my Haynes I have just used an mx5 m/c and fixed bias valve, but replaced the reservoir with a remote one (focus) atop the bulkhead
remember we are not mad just creatively insane !!!!!
joneh
posted on 28/12/15 at 07:13 AM |
Fiat 126 is used a lot. A few of the supplies, CBS or Rally Design do some kit aimed ones too.
melly-g
posted on 28/12/15 at 01:41 PM |
Mk1 fiesta non servo master cylinder.
I put one on mine to replace the standard Sierra cylinder, loads more feel slightly more travel.
locost7-online.com
posted on 28/12/15 at 06:34 PM |
I will take a look at the fiesta one, what compensator will I need to use too?
SJ
posted on 29/12/15 at 08:57 AM |
Fiat 124 on mine. Works reallyy well with the standard Sierra Disk, drum setup.
locost7-online.com
posted on 29/12/15 at 09:31 AM |
Sorted now thanks, ordered fiat 124 one, SJ can you give me an idea as to what port goes where please
SJ
posted on 29/12/15 at 07:00 PM |
Yes, the two rearmost ones are for the front brakes - one to each caliper, and the single front port goes to the rear drums [via the pressure switch
for the brake light on mine].
Stu
locost7-online.com
posted on 29/12/15 at 07:14 PM |
Great thanks that's what I thought, is the pressure regulator a fiat part or other? Also how have you done your brake light switch?
posted on 29/12/15 at 07:25 PM |
For the brake light put a switch on the brake pedal...
CosKev3
posted on 29/12/15 at 08:26 PM |
As above for the brake light switch.
Much more reliable.
Just converted mine to a switch on the pedal,as I found my brake lights were not working the majority of the time,until you really pressed them hard
which you hardly do under normal driving on the road.
SJ
posted on 29/12/15 at 09:33 PM |
I'll check my brake lights but they certainly came on really easily last time I checked.
Thanks for the heads up.
Stu
locost7-online.com
posted on 2/1/16 at 12:08 PM |
I received my master cylinder today, is there anywhere I can buy the rubber boot for the pushrod end for the fiat 124 cylinder?
