Mark Allanson
| posted on 14/10/02 at 10:10 PM |
Has anyone successfully used a Capri Axle
I have bought a Capri axle, but when positioned in the chassis, it has a wild amount of offset to the offside of the chassis.
I am sure I have read about members using this axle, perhaps they could help me out?
What did you do with the propshaft? Do I need to use the centre bearing? Is a propshaft offset from the centreline of the car acceptable to the nice
chaps at the SVA? Do I need to move the tranny tunnel over to the right and have the engine biased to the right as well?
I think that is enough questions to be getting on with (!!!), there are some images in the photo section to clarify my absurd ramblings.
Any help would be very much appreciated.
Mark
Liam
| posted on 14/10/02 at 11:17 PM |
Er, that's wierd. My mate used a capri axle and I'm sure the propshaft went in the middle! All I can say is are you sure you got it in the right
place? Sorry I can't help. Hmmm.
Liam
Macca
| posted on 14/10/02 at 11:20 PM |
May sound silly, but its not upsidedown is it? I can't tell from the pics.
Col
| posted on 15/10/02 at 07:56 AM |
Macca,
You're OK, that's perfectly normal!
(see my comments on TOL)
| posted on 15/10/02 at 09:34 AM |
Try this link...
http://www.vibratesoftware.com/html_help/html/diagnosis/propshaft/measuring_propshaft_angles.htm
Basically, each UJ mustn't have an angle greater than 4 degrees, but shouldn't be 0 degrees (causes excess wear).
Page shows what should be straight and what should be angled.
Simon
| posted on 15/10/02 at 11:59 AM |
Mark,
It may help to know that the Sierra driveshafts (appreciate not live axle) are different lengths, so while diff input is central, body of diff is
offest.
Any help?
Simon
James
| posted on 15/10/02 at 12:11 PM |
offest.
Any help?
Simon
I've been looking at mine and although the drive shafts are different the centre line of the diff' (ie. where the prop shaft joins it) should be
central to the car. It's just that the diff' output is larger on one side.
That's not a very good explanation- maybe this will work better:
The centre of mass of the diff needs to be offset but it should be mounted centrally.
does that explain it better?
James
| posted on 15/10/02 at 02:16 PM |
You have to remember that the differential is basically a crown and pinion gear set.
You can put the crown (big gear on the axle) in the middle and have equal length half-shafts, which means the pinion (the small gear that connects to
the propshaft) has to be offset to one side. This is the arrangement on the Escort/Cortina/Capri rigid axles.
Alternatively, you can put the pinion in the middle and offset the crown gear, which requires different length drive shafts - this is what they do on
the Sierra diff.
rgds,
Mark Allanson
| posted on 15/10/02 at 06:21 PM |
I measured the axle before I offered it up, the halfshafts are (seem to be) equal length (backplates to centre casting length) and the crownwheel
seems to be dead centre so the input flange is 1/2 the diameter of the pinion offset to the right (about 40mm).
I set the axle dead centre by measuring the back plates to the chassis, but I did ignore the height aspect.
I have roughly worked ou that with a 750mm probshaft the angle of the prop will be about 3 degrees or less. David on the Yahoo site says this is
ideal.
What prop angle is everyone else using?
Mark
P.S. I have put a sierra chassis plate decoder in the photo section, it may be of help to those using any sierra bits!
johnston
| posted on 15/10/02 at 08:18 PM |
if i remeber right it is actually in the middle but because the nose piece is a diffrent shape from the escy it looks ofset u just need to mod the
tranny tunnel (i think)
Nick Davison
| posted on 16/10/02 at 07:47 PM |
When I put my 2.8i axle in it was offset to the offside and would have fouled on the tunnel side by the drivers seat. I took out about 1" of metal
from the web it fouled on, this should not weaken it enough to do any damage.
I havn't worked out the prop angle yet but it should be ok!
Nick
