Poll: Poll - Tyre Pressures [View Results]
14
15
16
17
18
19
20
21
22
23
24
25
Author: Subject: Poll - Tyre Pressures
johnemms
posted on 28/3/16 at 11:51 AM Reply With Quote
Please select your road running psi.
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
jeffw
posted on 28/3/16 at 03:31 PM Reply With Quote
You need to define tyre and size before anyone can vote.
JAG
posted on 28/3/16 at 04:33 PM Reply With Quote
I run 185/60R14 tyres at 18 psi.
Justin
johnemms
posted on 28/3/16 at 09:40 PM Reply With Quote
185.70.13 Yokohama A021r 15psi cold has given nice even wear across tread.
Adamirish
195/50 15 Toyo T1R 15psi. Though I haven't experimented at all. It seems ok so left it at that!
MK Indy 1700 Xflow
bi22le
posted on 28/3/16 at 09:47 PM Reply With Quote
I have not been on the road for a while and when i was it was for road trips so hi psi for high mpg. It wad still a hoot to drive and slowed me down. That's only a good thing.
Please read my ring story:
posted on 29/3/16 at 08:10 AM Reply With Quote
185/50R15 tyres at 17psi in my MK Indy - much higher then that and the car became a little twitchy and slippery at the back end. A little toe in also helped on the rear end I found - done with very thin shim washers between the rear (Sierra) hubs and the MK supplied rear uprights.
sprintB+
posted on 29/3/16 at 08:46 AM Reply With Quote
185/70x13 running at 15psi
